Project Bike Thread: 81 GS650GL & 87 CBR600F
Articles, Essays, Reviews, Road Diaries, and your chance go Gonzo with your own weekly column. Be sure to read the FAQ before posting an article.
Re: Project Bike Thread: 81 GS650GL & 87 CBR600F
Postby red » Tue Apr 23, 2019 5:49 am
Test!
Edited! Hooray!
Jolly Roger
Postby DerGolgo » Tue Apr 23, 2019 10:06 am
red wrote:Test!
Edited! Hooray!
Jolly good!
I hereby officially declare this threadjack formally concluded, as per the disorganization byebyelaws.
You had been describing your intention to collect a substantial amount of stickers to make a collage?
I forget whether the matter of how to coat those for protective purposes had ever been resolved. Clearcoat bad, IIRC. Do you have an improved plan for that yet?
Location: It's bad enough I gotta live here, don't make me say it, too ...
Postby red » Tue Apr 23, 2019 6:06 pm
DerGolgo wrote:
red wrote:Test!
Edited! Hooray!
Jolly good!
My current plan is to have the tank acid dipped, then some enamel based rattle can. Once it's dry, it is sticker time! No more plans for clear coat.
Jolly Roger
Postby red » Fri Apr 26, 2019 11:23 am
I took some time the other night to open up the carb bowls to verify the jet sizes and that all the pieces were there. They look clean and complete. However, the gaskets look a little long in the tooth. I'm gonna roll the dice and try to use them. On the other hand, the intake boots are hard as rocks. I managed to track down a set and the thermostatic switch from evil Amazon. I threw a pair of cheap Chinese clip-ons on the order too.
Once I can get some space cleared in the garage, I'll finally get around to the valve check. From there, it's piecing it all back together. Once I have her running, I'll address the leaking forks, old tires, short chain and my lighting requirements.
When all of those are complete, it will be time for the fun stuff, mods! I don't plan on doing anything that isn't functional, just power outlets, heated grips and my top case.
Hooray for progress!
Jolly Roger
Postby red » Fri Apr 26, 2019 6:47 pm
Decided to rough sketch my plan for the tank stickering:
I have the following stickers:
2x Oxidizer 5.1
3x Flammable 1263 (3)
1x Caustic 1805 (8)
1x 3082 (9) Black & White stripes
I need to research the numeric codes for these for fun. Where is rench when I need him?
Jolly Roger
Postby red » Fri Apr 26, 2019 7:04 pm
Here's my assortment.
Jolly Roger
Postby Jaeger » Tue Apr 30, 2019 7:59 am
That's fucking tremendous. :mrgreen:
2018 Indian Scout
US Virginia
Postby red » Tue Apr 30, 2019 8:49 am
Jaeger wrote:That's fucking tremendous. :mrgreen:
Thank you! I hope the end result is as snazzy as my mock-up. I might need a few more placards to execute it properly.
I'm being green and trying to recycle junk from my garage to fab up bits-n-pieces that I need. For example, I have a metal bodied
toaster that I am scrapping to use as the tail section over the open portion of the frame above the tail light.
It's a fun challenge and appeals to frugal sensibility.
Jolly Roger
Postby red » Tue Apr 30, 2019 5:06 pm
The Servants of Amazon delivered to me the finest Chinese 37mm clip-ons and a MotionPro tappet adjuster tool.
With these clip-ons, I can add regular clamp mount mirrors and avoid bar-end style, leaving my tubes free for some hand guards.
I still have to clear out the garage so I can actually have room to do the valve service.
One step at a time.
Jolly Roger
Postby jae » Thu May 02, 2019 12:07 pm
I ordered a set of chinesium clip-ons like that one time (39mm for my sportster) and the pinch bolts broke almost immediately. If you haven't already done so, I'd highly recommend upgrading those bolts. Couple of bucks well-spent, in my experience.
jae
US Texas
Postby red » Fri May 03, 2019 5:16 am
jae wrote:I ordered a set of chinesium clip-ons like that one time (39mm for my sportster) and the pinch bolts broke almost immediately. If you haven't already done so, I'd highly recommend upgrading those bolts. Couple of bucks well-spent, in my experience.
Thanks for the tip! I have them installed (no broken bits yet) but they put too much of an angle on the reservoir, so I'm waiting for one for a GSXR600 from eBay. The piston is 1mm bigger, AZRider believes it will change the feel. If it does, no big deal, I'm only out $20.
I'd rather take that gamble over junk from Amazon. Solid aluminium like clip-ons is one thing, brakes are another!
Jolly Roger
Postby red » Wed May 15, 2019 12:09 pm
The progress continues!
Yesterday, I got the oil cooler relocated off of the radiator. I didn't have any flat stock to use. However, when I removed the horn to make room for the oil cooler, I realized its mount was made up of a few pieces of spring steel. A few quick bends and *poof*, I have my oil cooler mounts. The stock lines had to be zip tied to the frame to keep them from flapping around.
I was also able to remove the rock hard carb boots, a few came off in pieces.
Within the next few days, I'll have a new clutch lever, heated grip kit and grips from Revzilla. Then, I can button up the controls. Once those are done, I'm moving on to the valve check.
I'm too lazy to resize my pictures. You can see them here:
http://7plus8.blogspot.com/2019/05/project-cbr600f-making-progress.html
Jolly Roger
Postby red » Wed Jun 19, 2019 10:42 am
I've made some progress lately but I'm too lazy to post all the pics. Plus, I need to update the blog and that interface is much easier to work with.
The controls are all buttoned up, new clutch lever is on , and heated grips installed (not wired). The front brakes are now functional as well.
I attempted to do the valve service this past Saturday but
the tool I ordered wasn't even remotely correct, and my Honda 10mm adjuster tool from my Element wouldn't fit (screw and nut adjusters). So, I hit the net looking for the correct
Honda tool but came up nil. One poster recommend just grinding down the sides of a socket and using a wrench to hold it in place so you can run a screwdriver
down the center. Another just welded a bar onto the socket.
Not having access to a welder, I enlisted some outside help from someone with a little welding practice. It doesn't need to be perfect and it's not like I'll be needing it for
high torque values. The next day, I had my custom valve tool that cost me nothing more than a socket and wrench.
Next Saturday I'll have more garage time and get the valve service done and then start buttoning up the bike.
Jolly Roger
Postby red » Tue Jul 02, 2019 5:26 am
I tackled the valve service on Friday evening, using my fancy custom tool. It worked well but cylinders 1 and 4 were still a bit of a challenge on the intake side. The exhaust valves were all pretty much in spec, the intakes were all way too tight. I'm hoping there is no damage to the valves. They took the adjustment w/o issue. We'll see when I finally get to a test start.
The carbs are on the bike and cables are routed and installed but I realized I didn't check the float levels. I've got a fancy tool coming from Revzilla so I can check them correctly. I know if I skip them, it will come around to bite me in the ass. Once that is complete, it's on to stripping the tank, getting that painted and I can move on to test starts!
Jolly Roger
Postby Bigshankhank » Tue Jul 02, 2019 6:16 am
Yes, I don't know how sensitive the Honda's are to float height but on my Yamaha Maxim if they are off by more than 2-3mm the bike won't rev above idle, if it idles at all.
Excited to see your progress man, keep at it!
US Florida
Postby red » Wed Jul 03, 2019 5:01 am
Bigshankhank wrote:Yes, I don't know how sensitive the Honda's are to float height but on my Yamaha Maxim if they are off by more than 2-3mm the bike won't rev above idle, if it idles at all.
It's nice to put wrenches to something and not be rushed, which has taken me some time to learn to appreciate.
For those of you who want pretty pictures and more details, I'm keeping the blog updated as well:
http://7plus8.blogspot.com/2019/07/project-cbr600f-valve-service.html
Jolly Roger
Postby problemaddict » Wed Jul 10, 2019 4:09 pm
I can get you any assortment of Hazmat placard stickers you want. Explosive, Dangerous When Wet, Inhalation Hazard, etc. Plus, google any of those numbers with UN as a prefix and you'll find the specifics. 1263 is Paint. 3084 is Environmentally Hazardous Substances, 1805 is Phosphoric Acid...
US Pennsylvania
Postby Bigshankhank » Wed Jul 10, 2019 4:24 pm
problemaddict wrote:I can get you any assortment of Hazmat placard stickers you want. Explosive, Dangerous When Wet, Inhalation Hazard, etc. Plus, google any of those numbers with UN as a prefix and you'll find the specifics. 1263 is Paint. 3084 is Environmentally Hazardous Substances, 1805 is Phosphoric Acid...
Shit, I remember when I was working on the Deepwater spill I had ot get HAZMAT and HAZWOP certified and had a copy of the quick reference book with all of those UN numbers, and even in my lat 30's at the time I still scrolled through it looking for funny/disgusting materials because we boys are forever 14 years old in some part of our brains.
US Florida
Postby red » Thu Jul 11, 2019 9:26 am
Awesome, thanks! I won't know my real layout until I get the tank acid dipped and painted. Then I will start plotting out my design.
Jolly Roger
Postby red » Wed Jul 17, 2019 5:41 pm
Much progress, hooray!
While setting the float heights, I noticed how chewed up some of the bowl screws were, so I replaced those and the diaphragm cover screws with allen head hardware. I suppose some day I should buy a set of JIS screwdrivers but that wasn't the day.
With the floats set and the carbs assembled, I got them back on the bike with minimal profanity and injuries. A little hand sanitizier lubed up the boots and they slid right in. The left side intake "tube" was removed to make room for all the mess of wiring I need to hide around the airbox. The fuse block is zip tied to the side of the frame but definitely needs a better location (eventually. maybe).
I went a head and installed the tank and seat because I could resist sitting on the bike and day dreaming (well, it was a night but I was awake. Is that still day dreaming?) about actually having time to ride. Then I made some vroom vroom braaap braap noises and went to bed.
There is a cheap and questionable gel battery on it's way from Amazon. Once I have that in my grubby little hands, all I needs is the precious guzzoline, coolant and oil. Then it's test start city. I'm already preparing myself to see fuel pissing out of every part of the carbs while the bike struggles to start and makes all kinds of terrible metal on metal sounds from the engine. Or, it will fire up and be ready to rock. I bet that shorty can is gonna be awful.
If you want to see pictures, clicky here. No wait, here: http://7plus8.blogspot.com/2019/07/project-cbr600f-revenge-of-jis.html
Sorry, I'm too lazy to resize everything so I can upload them here and too cheap to pay for hosting.
Jolly Roger
Postby red » Mon Jul 29, 2019 6:27 am
With jugs of oil, coolant and a fresh can of gas, I was excited to do some test starts this Saturday. However, that didn't happen. I filled the radiator and overflow tank, only to hear "drip drip drip drip drip" coming from the left side of the bike. I found 3 spots that are leaking coolant. The lower rad hose is damaged on the underside and the o-ring in the left intake port to the engine is brittle and leaking. Hooray for liquid cooled bikes!
Later, I noticed oil in the coolant catch pan I put under the water pump. My brain goes into panic mode: RED ALERT! Thankfully, it was coming from the pulse generator cover. This thing is hemorrhaging fluids! The gasket is made from unobtainium, so I'll be rocking the ULTRA Black RTV.
I expected leaks, just not from the places that were leaking!
O-rings and RTV will be ordered soon, then it's a trip to the auto shop to try and find a suitable rad hose to replace the leaking one.
Oh, I picked up an inexpensive (maybe cheap) gel battery and got it mounted. My tail, brake and plate lights work! So, that's something!
Jolly Roger
Postby Bigshankhank » Mon Jul 29, 2019 7:14 am
Dude the anticipation is killing me!
US Florida
Postby red » Mon Jul 29, 2019 9:57 am
Bigshankhank wrote:Dude the anticipation is killing me!
Same here!
My big worry is fuel leaks. I had a CL450 that was a fuel sprinkler. It seemed every gap, crack, crevice and space on those carbs sprayed out fuel.
The CBR's carbs were cleaned and function checked and, new boots on the intakes, so I'm cautiously optimistic.
Jolly Roger
Postby Bigshankhank » Mon Jul 29, 2019 11:21 am
When you went through the carbs, did you split the rack or leave them all together? Not sure how they work but if they are anything like the XJ carbs, there'll be o-rings on the ends of the inter-carb fuel pipes that'll dry out and crack, also seals (not o-rings) on the throttle shafts. In the XJ community they refer to splitting the rack as "taking them to the Church of Clean".
US Florida
Postby red » Mon Jul 29, 2019 3:33 pm
Bigshankhank wrote:When you went through the carbs, did you split the rack or leave them all together? Not sure how they work but if they are anything like the XJ carbs, there'll be o-rings on the ends of the inter-carb fuel pipes that'll dry out and crack, also seals (not o-rings) on the throttle shafts. In the XJ community they refer to splitting the rack as "taking them to the Church of Clean".
I didn't disassemble them from the bank. So I have no clue about the o-rings. I'm just hoping for the best. When I took them apart, I cleaned the jets and bowls, checked the diaphragm and etc.
Jolly Roger
Postby red » Sat Aug 10, 2019 11:38 am
New rad hose has been installed, coolant intake o-ring replaced and RTV gasket for the pulse generator cover is curing. In 24 hours, I can top off the oil and coolant, and then put the tank back on and hit the red button!
Pics and full details here:
http://7plus8.blogspot.com/2019/08/project-cbr600f-plug-it-up.html
Jolly Roger
Postby red » Sun Aug 11, 2019 9:42 am
Project LOL continues. Slight leak on my RTV gasket, not surprised at that. However, no more coolant leaks, hooray! The real misfortune came when I added fuel. The petcock has a very good leak and the fuel joint tube between carbs 2 and 3 is leaking like crazy. At first, I thought it was the bowl but after pulling the air box and carbs, I noticed the tube was wet.
There are at least 14 o-rings that I'll need to replace if I break the carb bank apart. Thankfully, they'r pretty cheap, no wait, they're $3 each and about 10 mm in diameter. I'm curious if I can source a non OEM replacement for less.
The fun continues!
Jolly Roger
Postby Bigshankhank » Sun Aug 11, 2019 2:21 pm
Sorry I mentioned it now, didn’t mean to jinx ya but better to find out in the garage then out on the road.
US Florida
Postby red » Sun Aug 11, 2019 3:43 pm
Bigshankhank wrote:Sorry I mentioned it now, didn’t mean to jinx ya but better to find out in the garage then out on the road.
Florida Man jinxes local man's motorcycle project, tonight on Dateline.
With how crispy other o-rings have been, I'm not really surprised. I've found the replacements from Honda but I'm gonna try local sources ( read: Harbor Freight) first. This bank doesn't seem to be too difficult to separate.
Found a replacement petcock but it's from Alibaba and I'm terrified of buying stuff from there. Between stolen credit card info and brushing scams, I'm not sure I'm up for that adventure. Might grab a Chineseium universal from Amazon.
Jolly Roger
Postby Bigshankhank » Mon Aug 12, 2019 3:21 am
Do you have JIS screwdrivers? Its quite helpful if you do, but I was able to tear apart the carb bank on my XJ without them. I then replaced everything with stainless allen head bolts. Adds to the cost but if you ever have to take them apart again...
Also, don't overlook the throttle shaft seals between the carbs. You're going to be in there anyway and they will be a source of air leaks and will make tuning impossible if they are hard or leaking.
US Florida
PreviousNext
Return to Features & Columns
Users browsing this forum: No registered users and 8 guests
