My Harley is leaking oil...
Broken, fixed or fabricated.... Yak about it here.
Postby Rench » Mon May 27, 2019 8:10 am
But seriously... She is. First time oil leak in 15.5 yrs looks to be coming pretty clearly from the rear head gasket, and also lacking some punch on acceleration. On a quick search, lots of folks say they've never seen a blown head gasket on a sportster, to just check valve covers.
The loss of power kinda seals the deal for me but I thought I'd che k with the hive mind. Thoughts?
.-Rench
US Chicago
Re: My Harley is leaking oil...
Postby DerGolgo » Mon May 27, 2019 8:21 am
Loss of oil and loss of power?
How would valve covers affect power?
I may be an utter ignoramus when it comes to swinging a wrench, but just from applying the logics to what little I know of four-stroke otto-cycle engine design, head gasket does sound like a likely culprit.
Is checking compression in the cards?
Location: It's bad enough I gotta live here, don't make me say it, too ...
Postby red » Mon May 27, 2019 9:53 am
Sounds like how my Ulysses behaved around the time I found my front head gasket leak.
Jolly Roger
Postby Sisyphus » Mon May 27, 2019 3:22 pm
You're losing more compression than oil.
My money says head gasket. I had a head gasket fail on a diesel engine and power was somewhat diminished but it was pressurizing the coolant system. Because your bike isn't liquid cooled you wouldn't have this indication.
I bet if you pulled the head off you'd see witness marks in the form of carbon leading to where you found oil weeping out.
If you're lucky it'd just be a matter of cleaning everything off and seating a new head gasket with the proper torque and re-torquing after a heat cycle or two, depending on the manufacturer's protocol.
Postby 0l4fderstout » Tue May 28, 2019 7:04 am
what does a compression test say? (if it is the head gasket, I'd get the head milled before reseating it, so the gasket isn't as likely to blow out in the future)
0l4fderstout
US Michigan
Return to Tech Stuff
Users browsing this forum: No registered users and 0 guests
