There is an interesting new thesis:
http://www.motherjones.com/environment/ ... id=1202138
It takes them two whole sub-headlines to get to the beef, but it is thus:Kevin Drum on motherjones.com wrote:New research finds Pb is the hidden villain behind violent crime, lower IQs, and even the ADHD epidemic.
This is intriguing. I've heard the same effects attributed to Roe v. Wade, this is also mentioned, but unlike the Freakonomics guy who came up with that, this was investigated and found to be not just plausible but probable by actual scientists. Note that I do think economics is a science, I just don't think there are presently any actual scientists in that field. And an "upside-down U pattern"?? Is it honestly beyond the average reader of Mother Jones to know what a damn normal distribution or bell curve is?Kevin Drum on motherjones.com wrote:A recent study had suggested a link between childhood lead exposure and juvenile delinquency later on.
Lead emissions from tailpipes rose steadily from the early '40s through the early '70s, nearly quadrupling over that period. Then, as unleaded gasoline began to replace leaded gasoline, emissions plummeted.
Gasoline lead may explain as much as 90 percent of the rise and fall of violent crime over the past half century.
Intriguingly, violent crime rates followed the same upside-down U pattern. The only thing different was the time period: Crime rates rose dramatically in the '60s through the '80s, and then began dropping steadily starting in the early '90s. The two curves looked eerily identical, but were offset by about 20 years.
Very interesting, not proof of causation, but quite definitely beyond mere correlation. But lead was in the petrol everywhere, not just in the USA, so unlike Roe v. Wade, the effect should have manifested all over the place. Did they?Kevin Drum on motherjones.com wrote:If childhood lead exposure really did produce criminal behavior in adults, you'd expect that in states where consumption of leaded gasoline declined slowly, crime would decline slowly too. Conversely, in states where it declined quickly, crime would decline quickly. And that's exactly what she found.
Now, once upon a time, medicine would only endorse any new treatment when it's mechanism of action was well explained, empirical evidence of efficacy be damned. This is why naturopathy and other "alternative" forms of medicine were ignored for a long, long time. But these days, from what I've gathered, medicine damns the mechanism and just cares about empirical evidence of efficacy, statistics that show it to work or not. If that's good enough for finding something that cures, it's reasonable to accept the same standards for things that make ill, isn't it. Science may yet find other reasons for the development of crime and debunk this, but for now, this doesn't just make sense, it makes compelling sense, I think.Kevin Drum on motherjones.com wrote:Nevin collected lead data and crime data for Australia and found a close match. Ditto for Canada. And Great Britain and Finland and France and Italy and New Zealand and West Germany. Every time, the two curves fit each other astonishingly well. When I spoke to Nevin about this, I asked him if he had ever found a country that didn't fit the theory. "No," he replied. "Not one."
As regards the title of this thread, Clair Patterson was a geochemist who, in the middle of the last century, was working on radio-isotope dating the age of the earth. It took him many, many years, mostly because wherever he went to take samples and analyze them, there'd be lead pollution all over the place. He was one of the first to notice it and spend the rest of his life campaigning against the use of lead in gasoline and other industrial processes. He published scientific papers on lead pollution, and while he is largely forgotten these days, he is credited with pushing regulators to clamp down on the industrial use of lead and use in gasoline in particular. Considering the findings described above, he easily stopped more crime than any law maker ever, just with the fierce, blinding power of science.
And yes, he was a guy named Clair, maybe that's one of the reasons few people talk about his work these days. He did end up figuring out the age of the earth, eventually.
If Clair Patterson is the Batman of this story, Thomas Midgley Jr. might be Mr. Freeze.
After he invented tetra ethyl lead, he wanted to come up with a refrigerant that wouldn't kill people if a fridge or air conditioned sprang a leak, as often happened in the 1920s. A noble goal, but what he came up with was Freon, CFCs. After dooming the ozone layer, he got polio. To deal with his disability, he designed a system of levers and pulleys to help him get in and out of bed without assistance. Something went wrong and his contraption strangled him to death. Not a nice way to go, and probably not one he deserved. While putting lead in gasoline was a matter of greed and disinterest in, if not contempt for, the possible side effects of blowing all that lead into the air, he invented freon because, back then, hundreds of people would die at a time from a leaky AC in a hospital, or a broken fridges would wipe out entire families. Hate him as much as you will for the lead, with freon he had at least good intentions.
EDIT: Now, come to think of it, there might be a reason to connect this to politics, but only on the margins.
If juvenile lead exposure indeed makes people act immoral, unethically and, most importantly, dumber and without empathy, which is what a violent criminal is doing, is there perhaps a correlation between that lead exposure and ... the rise of conservatism? I don't mean regular old conservatism, mind, I mean Thatcherite, neo-liberal, corrupt, winnner-takes-all, Friedmanite conservatism, as we seem to have seen in the last thirty years or so. I'd be interested to see some data on when lead was phased out in the parts of the US where your tea party movement has the most followers. Was it later than in the areas where people are more, well, sane?
