Technically this is my son's.
At least Chuck's PT is a turbo, this has the plain jane 2.4l I4 engine, no frills. I will say The Boy is dissappointed that he wasn't comfortable in this, and truth be told with as wobbly as the suspension is (refer to the ball joint comments above) I think its better that he not be behind the wheel.problemaddict wrote:Wait. Your son had a cool-as-shit Raider and he let you have it in exchange for a fucking PT Cruiser?!? (I hope Mean Chuck doesn't see this post! LOL).
Sounds like my first Jeep, 86 CJ7. The leaf springs were practically flat due to DIY lift shackles, the sway bar was so loose you could shake it and every other component was worn out. The previous owner fancied himself a mechanic, spoiler alert, he wasn't.Bigshankhank wrote:... and truth be told with as wobbly as the suspension is (refer to the ball joint comments above) I think its better that he not be behind the wheel.
It sounds like he was trying to kill himself.red wrote:
Oh yeah, he also pulled the rollover valve off the gas tank but never plugged the holes, so I could only put 1/2 tank of gas in at a time or I left a flammable trail everywhere I went.
link not working for me . this ? https://jalopnik.com/heres-why-a-mitsub ... 1831046049" onclick="window.open(this.href);return false;
Only real drawback is a lack of aftermarket support, even from when they were new.
Bigshankhank wrote:Only real drawback is a lack of aftermarket support, even from when they were new.
I think that requires some digging, because the valence that the wiper motor is behind cannot be easily removed. I think I have to go through the firewall.MATPOC wrote:PULL THE WHOLE WIPER MECHANISM, might need it, those pivots and balljoints usually wear out
...that you can flake off with a fingernail?Bigshankhank wrote:... I decided to check the date code on the spare, 19th week of 1990.... Its got like-new tread on it though.
Pretty much, in fact the rim itself has mildew growing on it, its been that long since its seen the light of day.Jaeger wrote:
