SECURITY ADVISORY!
Today, 2020/11/18, suspicions have been expressed that there has been a data breach.
At least some DisMembers' login data may have been compromised.
While the facts behind those suspicions have not yet been established, your Administerrerr is treating them as credible. He is looking into this. He will try and beef up security.
Even if you did so only recently:
Please change your password!
Please click here, or use the menu ( button) to navigate to the the User Control Panel, therein to the Profile Tab, and there click Edit Account Settings. You should get it from there on.
For a safe password that will resist brute-force attempts (which we have been subject to in the past), please use upper and lower case letters, AND numerals, AND symbols, and make it as long as you feel feasible. 16 characters seems to be recommended these days.
DO NOT use a password you also use elsewhere.
While your Administerrerr tries to keep this place safe. Get real. Security here is mostly by obscurity, that is, no one serious enough to crack us like a rotten egg is likely to even bother. But if one does, you don't want the safety of your email of facebook or whatever to depend on one mostly blind, mostly clueless autodidact who can't work at this more than a few hours at a time, if that much.
If you used a password here that you also used elsewhere, you must set a new password there, also!
A different password, this time. If someone did breach us, the first thing they are likely to do with your login credentials is to try them out elsewhere. Login credentials compromised here are compromised everywhere else, also. If you did reuse a password, but with a different email, your administerrerrerr strongly urges you NOT rely on that different email keeping you safe. This whole thing runs on a database. That means your half-blind administerrerrerr can operate a database. Do you honestly think identity thieves, and those who sell them passwords by the ten-thousands, won't?
If you get an error message about an invalid form, click here.
Every form you can debauch is on a time limit. Even if you feel you've been reasonably quick, some browsers seem to think otherwise.
Recommendation: type your password in something like a text editor or word processor, highlight (making sure not to highlight any leading or trailing spaces), copy, then reload the account settings page, paste, paste, debauch, and be all quick about it. Like Dan said, back in the when. Be like the housefly, and see the events of the world unfold in liquid slowness, or something to that effect.
If you cannot reset a forgotten password, click here.
The "I forgot my password" function has been buggy for a while, I apologize. I will look into that, also, over the next few days.
You yourself, meanwhile, might look into your SPAM folder. I know, I know, but humor me, please.
Also, if you have been around for a bit, try and remember whether the email you entered there was also the email you registered with back in the when. I'm sure the email addresses associated to some user-accounts are still hotmail.
If none of that solves your confound, hit me through the contact form, or grab me via dm on the Facebooks, or if none of that works, speak up in the Midget Circus. I will look out for you there, but I can't guarantee nothing.
Nathaniel project
Discussion for the Akira Powerbike Page.
Nathaniel
Lurker
Nathaniel project
Post by Nathaniel » Fri Jun 20, 2008 5:48 am
I was disappointed to see here that I'm not the first person to realize a hydraulic final drive may be an excellent fit to this sort of design :)
Someone did a hydraulic final drive motorcycle: http://www.hydraulicinnovations.com/
I have a couple models at the url in the subject of two seater motorcycles with gas or electric power, and a full cowl, and a single seater scooter based (much simpler final drive) model with a full cowl. And a few car ideas. I think they're all pretty realistic, no massive chopper flop, significant consideration for final drives, no massive clearance / cornering issues as in Kaneda's original.
PS: my Website: http://www.eternalmachinery.com
Post by piccini9 » Fri Jun 20, 2008 7:23 am
Not so keen on the choppers but I love the "raccoon".
wongodog
Post by wongodog » Thu Jul 31, 2008 7:05 pm
An old Portagee blacksmith I used to know built something like
the Raccoon in the early seventies.
A couple of years later he turned it into a rototiller.
Post by xtian » Thu Jul 31, 2008 11:34 pm
don't they use an hydrolic transmission on the honda DN01 already ?
Nathaniel
Lurker
Post by Nathaniel » Fri Aug 01, 2008 6:56 am
xtian wrote:don't they use an hydrolic transmission on the honda DN01 already ?
By hydraulic final drive I mean replacing the chain or drive shaft in a motorcycle with hydraulics. A lot easier to get under a much lower seat than a chain or shaft. At least I think it would require less massive modifications to existing transmissions.
Post by xtian » Fri Aug 01, 2008 9:00 am
yes. excuse me I'm not a purist, does the hydrolic part of the honda only concern the automatic gear box then with still the use of a shaft ?
I think yamaha used it on the front wheel of its 2WD dirt bike then.
NEO
2x2
Post by NEO » Sun Aug 03, 2008 3:59 am
xtian wrote:Does the hydrolic part of the honda only concern the automatic gear box then with still the use of a shaft ?
The hydraulic part of the honda DN-01 only concern the automatic gear box.
Final Drive: Shaft
DN-01 -> Discovery of a New Concept 01
HFT -> Human-Friendly Transmission
xtian wrote:I think yamaha used it on the front wheel of its 2WD dirt bike then.
Several models:
- Yamaha Off Road Bikes
http://www.yamaha-motor-europe.com/desi ... ts%20roots
http://www.yamaha-motor-europe.com/desi ... otorcycles
http://www.yamaha-motor-europe.com/desi ... F%202-Trac
- Yamaha R1
http://www.sportbikerider.us/index.cfm? ... e_ID=21745
http://www.motards-online.com/n4_66_Yam ... grale.html
Prototypes KTM, Suzuki Nuda, etc...
Old link, hydraulic motorcycle 2x2x2:
http://home.mira.net/~iwd/2x2x2/index.html
