Yes, it is that one. Basically a variable-voltage mod with just one blinking eye to tell you when you're being stupid. Unlike other VV mods, it has high current protection, short-circuit protection, over-heating protection for its innards and over-puffing protection for its user. It handles 45 Amps and if you find the sweet-spot at 0.18 Ohms, it will actually deliver 240W, at a mere 36.7 Amps.jae wrote:I don't know if you're specifically limiting your search to local(ish) sources, but is this the one?
https://www.bigmarvel.com/tesla-invader ... w-box-mod/" onclick="window.open(this.href);return false;
Blink once for yes, twice for no and 15 times for low-battery. Also 5-click on and off switch, which is the first thing you miss when you get an old-fashioned VV mod.
Unlike other, top-range mods, this one does NOT rattle when you shake it, everything fits as it should, the battery door stays in place, no paint will chip off of the voltage dial after a just a few days. 6.6V max, no step-up. But quite enough.
The original problem I had was that the thread of the 510 connector came out when I tried to unscrew my atty. That chrome-plated "rim" of the 510 you see in the pics is a sleeve, a thread inside and another outside. Unfortunately, both are right-handed threads, so when for some reason my atty was a bit tight in there, the outer thread would unscrew.
Now, that I've destroyed the damn thing, I know how what and why all things in there connect with each other.
If the threaded sleeve comes out for you, do not despair. Around the opening in the casing that it fits in, there is a recessed rim, which a rim at the top of that threaded sleeve fits into.
THERE, and nowhere else, apply a tiny amount of Gorilla Glue, in that recessed rim around the opening. Insert, screw down and make fast with a clamp that threaded sleeve and go eat a banana.
Afterwards, it should sit tight and be good.
[media]https://youtu.be/yAJrsd0jW6U?t=16s[/media]
EDIT: $42.99 domestic is a STEAL, that's what Chinese retailers charge.
